I'm building a system around an ASUS GTX 780 GPU which I already have, and want to double-check that it will be compatible both with the single card I already have and with a second I may add in future (because apparently it's cheaper to upgrade by SLIing a second identical card than buying a new, replacement, top-of-the-range future card (although let me know if this advice is untrue)).
COOLERMASTER CM690 MKII ADVANCED CASE
Intel® Core™i5 Quad Core Processor i5-4670 (3.4GHz) 6MB Cache
ASUS® Z87-A: ATX, USB3.0, SATA6GB/S, SLi, XFIRE + **FREE GAME**
8GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (2 x 4GB KIT) ATX, USB3.0, SATA6GB/S, SLi, XFIRE
CORSAIR 1000W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
GPU
2x ASUS GTX780-DC2OC-3GD5
I especially don't understand the specific types of power connector that the cards require, but since PCS would let me build a system with a GTX780 from them I'm assuming the PSU has enough of the right connectors for at least one such card. I'm also not sure if the motherboard can take two large cards side-by-side (although I know the case can fit them). I'm sure these are silly questions and that the cards are probably sufficiently narrow that two can be placed side-by-side in the two PCI-E slots but I want to make sure before I buy. Thanks.
GPU
