My laptop power and battery charging lights have started to flash when my AC adapter is plugged in (which is a new replacement one that I had to get a couple of months ago from a different supplier since the replacement one PC Specialist sent me wasn't the right size and I was informed that you didn't have the right size in and wouldn't be able to get it in for a couple of months), and the battery won't charge. There's no flashing when the adapter is not plugged in. I have tried taking out the battery and powering on the laptop so as to reset the battery but that has not worked. If I take the battery out then the laptop works with just the AC adapter connected. The battery charging light also flashes when the AC adapter is plugged in and the laptop is switched off, so I presume the battery charges when the laptop is off, it just won't when the laptop is on. Is it just that I need a new battery (which PC Specialist are out of stock off) or could there be a problem with the laptop itself?
Thanks
Dave
Thanks
Dave
