I am more than happy with the spec and price. I am just worried about the quality of the casing itself, what its like to type on, plastic or metal etc and I couldn't find any info on those details. I'm choosing between the enigma and a modified Vaio C series. (The C series looks amazing, which is why I would like to know about the Enigma).
For everything else the Engima beats the Vaio hands down!
Many thanks if anyone can help
eli.
Chassis & Display
Enigma III 540: 15.6" Full HD LED Widescreen (1920x1080) Super Clear Glossy
Intel® Core™i5 Dual Core Mobile Processor i5-2520M (2.50GHz) 3MB Cache
nVIDIA® GeForce® GT 540M - 2GB DDR3 Video RAM - DirectX® 11
Memory - 1st Hard Disk
500GB WD SCORPIO BLACK WD5000BEKT, SATA 3 Gb/s, 16MB CACHE (7200 rpm)
1st DVD/BLU-RAY Drive
Integrated 3 in 1 Memory Card Reader (SD, MMC, MS)
Network Facilities
GIGABIT LAN & INTEL® CENTRINO® ADVANCED-N 6230 inc BLUETOOTH
1 x USB 3.0 PORT + 2 x USB 2.0 PORTS AS STANDARD
Battery
2 x Enigma III Series 6 Cell Lithium Ion Battery (5,100/5,200 mAh) (£39)
Power Lead & Adaptor
1 x UK Power Lead & 120W AC Adaptor
eli.
Chassis & Display
Network Facilities
Battery
