Eyefinity & Speed!
wiserommer
I've decided to dable at trying to make an eyefinity setup, always wanted one! what do you think of this setup...£1300 budget :)
AMD PHENOM II X6 1055T (2.80GHz/9MB CACHE/AM3/) - (Special Offer)
ASUS® M4A87TD/USB3: DUAL DDR3,SATA 6.0GB/s, USB 3.0
8GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz (4 x 2GB KIT)
1GB AMD RADEON™ HD6850 - 2 DVI,HDMI,mDP - DirectX® 11, Eyefinity 3 Capable
Memory - 1st Hard Disk
120GB OCZ VERTEX 2 SATA II 2.5" SSD (upto 285MB/sR | 275MB/sW)
2nd Hard Disk
640GB WD CAVIAR BLACK WD6402AAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
1st DVD/BLU-RAY Drive
450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan (£29)
Network Facilities
NO OPERATING SYSTEM REQUIRED
NO OFFICE SOFTWARE
Monitor
EYEFINITY 3 x IIYAMA E2271HDS 22" LED WIDESCREEN (£417)
Standard Build - Approximately 9 to 13 working days
Quantity
1
Price: £1,278.00 including VAT and delivery.
Sleinous
I would say, bump up the PSU to a 600W to give a bit more margin for starters :p
Very nice setup though!
Good choice of 64mb cached drive.
PCS
Administrator
Staff member
You also need to order the Eyefinity kit from the Eyefinity category. You will need the mini Display Port to DVI adapter.
