wats a computer???
Hi i bought a pc from ye just over a year ago!
The problem i have is a minute one, a few weeks ago i just turned on my pc and was about to log into facebook when i got the blue screen of death.
Now any time i start my pc a window appears at the start! The background is blue for top half with Asus Express Gate in top right corner and black background for bottom half! There are 7 icons in total at the bottom of screen! Power off is closest to right hand corner and and an exit icon that has a 10 second timer over it if i don't move mouse! once i click the exit icon one of the fans start to work overtime (i haven't a clue which one) and this is my problem the noise is alot higher than it was prior to blue screen as i could barely hear the pc!! Any info as to the problem would be great..
Also i need to get new usb ports as i kneed the usb connector on my head set upwards and broke the usb ports!!
This is spec of my pc if its any help!
Case COOLERMASTER HAF-X FULL TOWER GAMING CASE
Processor (CPU) Intel® Core™i7 Six Core Processor i7-970 (3.20GHz) 6.4GTs/12MB Cache
Motherboard ASUS® P6X58D PREMIUM: DDR3, USB 3.0 & SATA 6.0GB/s, 3-Way SLI
Memory (RAM) 12GB KINGSTON HYPER-X TRI-DDR3 1600MHz, X.M.P (6 x 2GB KIT)
Graphics Card 1536MB NVIDIA GEFORCE GTX580 GDDR5 PCI EXPRESS - DX 11 (PRE-ORDER)
2nd Graphics Card NONE
3rd Graphics Card NONE
Memory - 1st Hard Disk 1TB WD CAVIAR BLACK WD1002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
2nd Hard Disk NONE
RAID NONE
1st DVD/BLU-RAY Drive 10x BLU-RAY RE-WRITER DRIVE, 16x DVD ±R/±RW (£88)
Power Supply CORSAIR 1000W PRO SERIES (HX1000) 80+ MODULAR PSU (£169)
Processor Cooling COOLIT ECO C240 A.L.C (ADVANCED LIQUID COOLER) (£102)
Sound Card Sound Blaster® X-Fi™ Titanium PCI Express (£59)
Network Facilities WIRELESS 802.11N 300Mbps PCI CARD (£16)
2nd Hard Disk NONE
RAID NONE
