Sorry if it's already been covered but what makes you think your ever going to need that much RAM, what program is it that requires it?You know what, this is definitely what ill do. Thanks!
Can get 128gb DDR4 3600MHz for around £500.
(The same cost difference as the 128gb DDR4 3000MHz in my current build).
I suppose some questions,
It is entirely fine to buy 2 x (2x32gb) packs instead of 1 x (4x32) pack?
The latter seems to be more expensive.
I'm aware there used to be major requirements to have RAM paired.
But I assume buying 2 of the same pair will work just fine? Instead of a 4 pack?
Thanks
For clarity I am looking at the
Patriot Viper Steel DDR4 64GB (2 x 32GB) 3600MHz Kit - PVS464G360C8K
or
Patriot Viper 4 Blackout Series DDR4 64GB (2 x 32GB) 3600MHz Kit -
PBS464G360C8K
