KevinKerrMusic
The reason I deviated from this was, I was getting one beep, straight into a post error screen. Continually til I managed to tweak the bios.Your manual shows the following:
Fairly standard. You should always check the actual manual rather than external sources. Large manufacturers will often customise the BIOS, significantly different from the likes of AMI or etc would have as default.
One beep made no sense in the context of this, especially when followed by a forced boot into bios.
I can only assume now the one beep is VGA detected as manual suggests!
Cheers
Edit- My apologies. Just noticed this is on the original thread.
