callum tubb
Hi, i am currently looking at the choices in gpu's and would like some help with what to choose from. The gpu's im looking at are the gtx 1660 super, rx 5600xt and the rtx 2060.
With a PC, the components all fit their use case, so you can't just advise on a GPU without knowing what it's pairing with and use case.Hi, i am currently looking at the choices in gpu's and would like some help with what to choose from. The gpu's im looking at are the gtx 1660 super, rx 5600xt and the rtx 2060.
Is it the PC that was recommended previously?I am going to be using the pc for mainly gaming as well as using editing software like photoshop.
The 1660 Super as configured is what would match your monitor.
The build that’s been suggested is the perfect build for your budget, it’s not built on a whim, it’s configured specifically to meet your monitor, and usage scenario and budget.hi i am just deciding my final part of my build but was wondering whether i should go for the AMD ryzen 5 3600 or the intel i5 9600k? Could anyone help
hi, is it easy enough to install a hard drive as i have on at home in my old pc and was thinking of putting that into my new pc
Im not overly sure what im going to be doing with the old pc but just wanted to save money on a hard drive. Im just not sure how difficult it is to install
Adaptive sync is the generic term which is where the monitor adjusts it's frequency to whatever the gpu is putting out. It reduces screen tearing and even when the GPU is older and putting out lower fps, it will still stay buttery smooth. It's a given these days that if buying a gaming monitor, you get adaptive sync.Hi, i am just looking into monitors and was wondering what AMD freesync is and if that only matters if u have an AMD GPU
What's your budget?Has anyone got any suggestions on a good 24inch monitor.
I have been looking at these so far:
BenQ ZOWIE XL2411P 24 Inch 144 Hz
Dell S2419HGF 24 Inch
OMEN by HP 25 Full-HD (24.5" ) LED Gaming Display - 144Hz, 1ms Response
