HELP! Best monitor for me? Please check PC specs | PCSPECIALIST
Junioru19
PCS PRISM-X RGB MID TOWER CASE
16GB SPEEDSTER MERC319 AMD RADEON™ RX 6900 XT - HDMI, DP - DX® 12
1TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
CORSAIR 850W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Extra Case Fans
Asus Xonar AE 7.1-Channel Gaming Audio Card
I am now waiting for it.
In the meanwhile i am looking for a monitor that suits me for the games i play. And i guess it should be freesync as per amd setup. I mainly play PUBG and CSGO.
I know for fact in CSGO (been playing for years on 144hz with over 250 fps) that 240hz monitor would be recommended, but for PUBG, based on my own research, is recommended to play at 1440p 144hz as it is hard to get high fps to play at 240hz.
My question is, even though the specs above are pretty good for 1440p, lets say all settings on low with textures and AA on ultra i would get an avarage of 180fps, should i go for a 1080p 240hz monitor? Or 1440p 144hz? (Ps. I never played CSGO on 240hz and i really want to push my limits.)
My other option was a 1440p 165hz 1ms monitor, was thinking that those 21hz extra might make a difference in PUBG.
I also want to start streaming and yet i am not sure if i should go for 1080p 240hz or 1440p 144hz (in PUBG)
I'll appreciate your help!
I would personally change pretty much your entire build mate to be honest.
The case the CPU the GPU the CPU cooler it's certainly not optimal for gaming
Can you include the configurable link and we can help out? We'll also likely save you a significant amount too while getting a more tailored build to your needs
Junioru19
Yes sure!
I actually hoped that the build would be alright trying to save some cash on some parts. I actually chose amd for both cpu and gpu as per availability (gpu mostly) and some benchmarks won by amd against competitors (cpu) i hope i can still change parts from it as i ordered it 3 days ago.
What would you guys go for?
Lets no forget which monitor should i go for haha
For a gaming build at the high end of 1440p I would go for this, it would comfortable handle 1440p 144Hz with no trouble and is more geared to gaming. The build listed in your link is more built for production in mind, like rendering or 3D modelling. This would be a strictly tailored gaming build.
I've changed the RAM, there's no difference between 3200Mhz and 3600Mhz when it comes to gaming
Changed the case to something more suitable to the parts so they wont cook inside
changed the motherboard to suit the CPU
Changed the storage set up, I'm assuming you need a lot it so I added an extra 2TB Sata SSD
Went for the best cooler available as the 5800X runs very very hot
Removed the soundcard as it's not needed unless you plan to do sound editing and mixing. Motherboards come with high quality sound cards these days
Added a better Wifi card that comes with Bluetooth 5.1 also
For a monitor I would be looking for a Samsung G7 or an ASUS TUF 1440p 240Hz option
GPU I went with a 3070 as it's the highest end 1440p card, if you wanted a 6900XT or a 3080 you would be looking at a £1000 monitor to make the most of the card like the Samsung G9
2TB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 470MB/W)
Corsair H150i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
Surge Protection
6 Socket 2m Surge Protector
Cable Management
3 x PCS 1.5M Zip Cable Tidy - Professional Cable Management
Price: £2,325.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/fdzvgVBehw/
