Help building a gaming pc?
Conkee
Hi, I've been wanting to buy some sort of beasty computer for about 4 months now, but I'm still a noob when it comes to building :( so I have £1,600 to spend and ill be wanting to game, video edit and do some schoolwork, (to please my dad) I'm also thinking about possibly two or three monitors, (acknowledging this will be a push for cash, also wanting it not to lag) I've heard great things about PCS and will definitely be buying from them, so some help would be much appreciated. Thanks
Conkee
Yeh it does, I understand that it's apush but will be looking to play games from Minecraft to battlefield :) I could just get two monitors and then save again for the third, if the price is a problem :)
Narcotics
COOLERMASTER CM690 MKII ADVANCED CASE
Intel® Core™i5 Quad Core Processor i5-3550 (3.3GHz) 6MB Cache
ASUS® P8Z77-V: PCI-E 3.0 READY, WIFI, SLI, CROSSFIREX
8GB SAMSUNG DUAL-DDR3 1333MHz (2 X 4GB)
2GB NVIDIA GEFORCE GTX 670 - 2 DVI, HDMI, DP - 3D Vision Ready
Memory - 1st Hard Disk
120GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
2nd Hard Disk
1st DVD/BLU-RAY Drive
12x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW (£52)
CORSAIR 750W PRO SERIES™ HX750-80 PLUS® SILVER MODULAR (£114)
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE INTEL CPU COOLER (£19)
Network Facilities
TV Card
HAUPPAUGE HI-DEF SATELITTE DVB-S2 TV RECIEVER (WinTV-NOVA-HD-S2)
Genuine Windows 7 Home Premium 64 Bit w/SP1 - inc DVD & Licence
Monitor
IIYAMA E2773HDS 27" LED WIDESCREEN, HDMI/DVI-D HD1920x1080 (£239)
Quantity
1
Price: £1,615.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/quotes/intel-ivy-bridge-pc/3oegf2E2cZ/
keynes
If you want to play in surround (3 monitors) and want to get high fps I'd recommend GTX 670 SLI and if money is an issue probably get the additional 2 monitors later on. If you still wish to get at least 2 monitors then you may need to downgrade the GPU and/or processor.
Intel® Core™i7 Quad Core Processor i7-3770 (3.4GHz) 8MB Cache
2nd Graphics Card
CORSAIR 750W ENTHUSIAST SERIES™ TX750 V2-80 PLUS® BRONZE (£86)
Network Facilities
Monitor
IIYAMA E2273HDS 22" LED WIDESCREEN, HDMI/DVI-D 1920x1080 (£129)
Quantity
1
Price: £1,633.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/quotes/intel-ivy-bridge-pc/MAJfBddGGF/
Narcotics
2nd Graphics Card
Network Facilities
Monitor
Quantity
1
Good point other option 3 of them monitors & crossfire 7850s
vanthus
Member Resting in Peace
ASUS® P8Z77-V LX: USB 3.0, SATA 6GBs, ATI®CrossFireX
16GB SAMSUNG DUAL-DDR3 1333MHz (4 X 4GB)
3GB AMD RADEON™ HD7970 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
Free Item
FREE DIRT SHOWDOWN GAME with any AMD 7000 Series GPU!
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£69)
Network Facilities
Monitor
2nd Monitor
3rd Monitor
Quantity 1
£1590 inc VAT and Delivery
Narcotics
Free Item
Network Facilities
Monitor
2nd Monitor
3rd Monitor
Quantity 1
This is a good option
keynes
Do you think the one graphics card would be enough?
It depends on what settings and frames per second you are expecting. I have attached a benchmark table for Battlefield 3 with 3 monitors.
keynes
So it would keep up? What are the advantages of your suggested setup over this one?
If you are planning to game in 3 monitors and keep fps at more than 30 then I'd go with the GTX 670 SLI however Vanthus's spec allows you to buy 3 monitors.
keynes
Hmm but what's yours do that his doesn't? :)
Higher frames per second at higher resolutions.
From Guru3d
Frames per second
<30 FPS very limited gameplay
30-40 FPS average yet very playable
40-60 FPS good gameplay
>60 FPS best possible gameplay
For Battlefield 3 at high settings the GTX 670 SLI would give you around 50 fps and the HD 7970 around 30 fps
vanthus
I suggested a build that would include everything you mentioned within your budget,
including 3 monitors,also a strong CPU & 16GB of ram for the video editing you mentioned,
but if gaming on 3 monitors on high settings is more important to you then best go with rubens spec.
