Help?! CPU running at 124 Celsius?!
vanthus
Member Resting in Peace
Try something like Core temp to see if it confirms the temps,if so check the CPU cooler isn't loose.Failing that try reseating the cooler or if confident enough renewing the thermal paste
Buzz
Master
That 124°c must be wrong as your comp would most likely shut off by about 98°c. I used speedfan before myself and also gave incorrect readings. Like vanthus said above, try core temp instead. see what temps you get in that
lloydehhh
Asus Suite is giving me 129 D: Going to leave off for an hour then check again, if it's still bad i'll check seating of cooler, and will replace thermal paste if it's seated fine :/
lloydehhh
Finally got temperature down to about 50C after replacing thermal paste, I just hope this incident hasn't done any damage to the CPU.
