L33s2good
Ok, 2 question's here, Firstly after i recieved my pc from pc specialist i had a trial windows 7 installed i then entered my product key to activate full version, when i go to c:// i have 2 program file folders one says (Program Files) the other says (Programe files x86) should i delete the (programe files folder?) im worried its taking up space with no need,
Second question, if anyone is used to the programe (FRAPS) is there a way to run on a seperate Hdd if i say split my 1tb in order to run fraps with more fps, i will be getting an ssd top improve this eventually but untill then an y tips to get it running with more fps while recording in game!
Cheers
Cheers
