OVerclocked PhenomII x6
ANTEC 900 BLACK GAMING CASE (£79)
Overclocked CPU
OVERCLOCKED AMD PHENOM II X6 1090T (3.20GHz @ MAX 3.80GHz)
ASUS® CROSSHAIR IV FORMULA: DDR3, USB 3.0, SATA 6.0Gb/s, R.O GAMERS
8GB CORSAIR XMS3 DUAL-DDR3 1600MHz (4 x 2GB KIT)
1GB ATI RADEON™ HD 5870 PCI EXPRESS - DirectX® 11
2nd Graphics Card
NONE
3rd Graphics Card
NONE
Memory - 1st Hard Disk
1TB SERIAL ATA 3-Gb/s HARD DRIVE WITH 16MB CACHE (7,200rpm)
2nd Hard Disk
NONE
RAID (HDD 1 & 2)
NONE
1st DVD/BLU-RAY Drive
2nd DVD/BLU-RAY Drive
NONE
INTERNAL 52 IN 1 CARD READER (READS XD, MS, CF, SD, etc)
Power Supply & Case Cooling
800W Quiet 80 PLUS Quad Rail PSU + 120mm Case Fan (£89)
TITAN FENRIR EXTREME DIRECT TOUCH COPPER CPU COOLER (£39)
STANDARD OVERCLOCK THERMAL PASTE
Network Facilities
This is the new pc im looking to buy i know some parts may be excessive but im trying to future proof it as much as possible with out spending to much, ive put extra power so i can put a second graphics card in later on if needed, is this balanced and safe to run for gaming on highest settings, since its overclocked will i have to ever have to set anything or can i just play games and it will be ok , im not great with computers so could do with some help any and all suggestions on specs and what this pc can do will be appreciated thanks.
Overclocked CPU
2nd Graphics Card
NONE
3rd Graphics Card
NONE
2nd Hard Disk
NONE
RAID (HDD 1 & 2)
NONE
NONE
Network Facilities
