Hey all,
First post here.
I've had a self build PC from 2016 but the motherboard has died and I'm looking to replace the PC.
The use is general office type work, multitasking, some video streaming (Plex, kodi etc), and potential basic gaming.
Budget could stretch up to £1000, but ideally £700.
I think my main priority would be to have a minimal and sleek looking case, to match with the study. No bright colours etc.
Looking to replace the spec below. I want to keep the hard drives, but wouldnt mind upgrading to larger main SSD.
Monitors might be upgraded in the next 3 years or so, but it's not a priority.
Could you please help with a spec?
Thanks a lot!!
Storage:
Optical Drive
PSU
Memory
CPU
GPU
Monitors (2off)
First post here.
Thanks a lot!!
Storage:
Seagate BarraCuda 6TB SATA III 3.5" Hard Drive - 5400RPM
2TB Seagate ST2000DM001 Barracuda 7200.14 SATA 3 6GB/s 7200rpm 64MB Cache 8ms OEM NCQ
250GB Samsung 750 EVO, 2.5" SSD, SATA III - 6Gb/s, Samsung MGX, 256MB Cache, Read 540MB/s, Write 520MB/s, 97K/88K IOPS
Optical Drive
LiteOn IHAS124-14 24x DVD±R, 8x DVD±DL, DVD+RW x8/-RW x6, DVD-RAM x12, SATA, Black, OEM
PSU
450W Corsair CS450M, 80 PLUS Gold, Hybrid Modular, Single Rail, 35.5A +12V, 1x120mm Fan, ATX PSU
Aerocool Dead Silence Blue Gaming micro-ATX Cube Case with Blue & Black Interior w/o PSU
Memory
16GB (2x8GB) Corsair DDR4 Vengeance LPX Black, PC4-17000 (2133), Non-ECC Unbuffered, CAS 13-15-15-28, XMP 2.0, 1.2V
CPU
Intel Core i3 6100, S 1151, Skylake, Dual Core, 3.7GHz, 3MB Cache, 1005MHz GPU, 37x Ratio, 47W, CPU,
Gigabyte GA-B150M-DS3H, Intel B150, S 1151, DDR4, SATA3 6Gbps, M.2 (PCIe/SATA), Realtek LAN, USB 3.0, Micro ATX
GPU
12GB Sapphire Radeon RX460 Dual-X, 14nm Polaris, PCIe 3.0, 7000MHz GDDR5, 1090MHz GPU, 1210MHz Boost, 896 Streams
Monitors (2off)
LG 23MP68VQ, 23 IPS (Neo Blade) Freesync, 16:9, 1920 x 1080/250cd/m2/5ms, VGA/DVI/HDMI, 75 Hz
