utd4life13
Hi guys,
I bought a PC from PCspecialist 2 years ago and haven't had any problems up until last week. The pc became considerably slower than usual. I use it mainly for Flight Simulator X and also was having problems with that were it kept crashing and the screen would go black and whitish like a graphics problem.
I decided to wipe it and restore using the windows 7 disc. However, the first time I tried to install it got all the way to 'completing instillation' and a blue screen appeared saying the PC would shut down to avoid damaging the hardware or something like that.
Since then I've tried on numerous times to install windows 7 and it just wont do it. Each time is different and it gets to different stages. The furthest I got was to 'Installing updates' which took 9 hours then it said it couldn't proceed to the next part of the instillation I think because something to do with rebooting error.
I've tried following guides on line and deleting the disc partitions before installing the OS but it doesn't work.
I've tried the restore section of the OS disc but is always says it can't do repairs automatically. Also it won't let me do a disc check on startup - in fact it won't let me do any of the recovery options.
I've also had a black screen which says BootManager is missing but it doesn't always say that and I've tried to resolve that by looking online but again couldn't.
I don't know what to do as I'm not sure what's wrong and I now don't even have an OS installed.
Any ideas what it might be and some guidance as to what I can do to fix it or at least determine what is wrong?
Any help Much appreciated.
Thanks,
Danny
Thanks,
Danny
