I need some Help guys
AwesomeDude
Right, I need some help guys I want a Spec Under £1750 with the following:
2X HD 7950
24 Inch Monitor
Performance Drive
Please Help guys I'm kind of in a dilemma. :)
Fear
What are you using the PC for ? also are you going to be using 3 monitors or just a single because 1 of those cards is more than enough for a single monitor.
bg92
Expert
Something like this would be good. I'm assuming that you need wind 7 included in the budget as well.
COOLERMASTER CM690 MKII ADVANCED CASE
Intel® Core™i5-2500 Quad Core (3.30GHz, 6MB Cache) + HD Graphics
ASUS® P8Z68-V/GEN3: PCI-E 3.0 READY, SLI, CROSSFIREX***SPECIAL***
8GB SAMSUNG DUAL-DDR3 1333MHz (2 X 4GB)
3GB AMD RADEON™ HD7950 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
2nd Graphics Card
Memory - 1st Hard Disk
1st DVD/BLU-RAY Drive
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£69)
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE INTEL CPU COOLER (£19)
Network Facilities
NO OFFICE SOFTWARE
Monitor
IIYAMA E2473HDS 24" LED WIDESCREEN, 2 HDMI/DVI-D 1920x1080 (£159)
Quantity
1
Price: £1,738.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/intel-sandy-bridge-pc/
Music Guy123
Do you mind if I ask why you need to crossfire now, a single 7970 should be able to max out everything on two screens. Then you can wait for the prices to drop a little and then you can get another.
Music Guy123
I would get one 7970 for now and then add another in a year or two time. That way it will end up cheaper and you will have more power for longer. But it is your choice.
