iCUE and H115i RGB
tierenobre
Hi people!
My PC arrived this week and I can't change the color of my Corsair H115i RGB PLATINUM Hydro Series. It does not appear to configure in Commander pro.
Could you help me with how to fix this?
Thanks in advance
steaky360
I've actually got the same issue - I'm not sure if its something to do with the USB header which the H115i is connected too.
I've not tried to troubleshoot it properly yet tbh "if it aint broke don't fix it"...
tierenobre
Can you post your full specs from the order page?
Yes I can
CORSAIR OBSIDIAN SERIES™ 500D SE CASE
ASUS® CROSSHAIR VIII HERO (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
4TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 5400RPM, 256MB CACHE
2 PORT (2 x TYPE A) USB 3.0 PCI-E CARD + STANDARD USB PORTS
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Standard Build - Approximately 25 to 27 working days
Promotional Item
Get Assassin's Creed: Valhalla with select SAMSUNG SSDs!
Welcome Book
Logo Branding
PCSpecialist Logo
tierenobre
Omg, it's good to know that I'm not alone in this hahaha. Mine is working fine, but I would like to have control and change the color.
Nooshkie
Mine comes up separate in icue as I’m pretty sure it’s not connected to the commander 🤷‍♂️ Through icue itself I’ve changed colour of all my rgb including the mobo try updating icue
Gavras
Master Poster
tierenobre
Photo of my controller shows there is no connection on yours on right hand side.
I don't have this USB cable (it's also not in the welcome pack)
So my question now is: This cable comes with the Corsair H115i, would the PCS have sent it to me?
Or do I need to buy it out?
Yes I agree. I will wait for the PCS to reply on this.
Thank guys. Thank you all!!
Don't use the PC if that cable isn't connected, that controls the Pump, without it the CPU will overheat and possibly damage the CPU and or motherboard.
Double check your USB headers on the motherboard, see if there's one leading to that cable that's fallen loose somewhere inside the case.
For them to forget it is really poor, I can't see how it would have passed testing as the CPU temp would have been obviously high.
