Issue with gtx 880m crashing!
thisisevilevil
trying to match my memory, was told by pcs to take back off and check model number, seams extreme lol
You can find the model/spare number of your existing DIMMs by using CPU-Z -> SPD. Partnumber.png
thisisevilevil
does it matter that they dont match exactly
As long as you make sure it's the same speed and voltage, it shouldn't matter really. In most cases they probably use the same chip anyway. In your case you would need SO-DIMM, DDR3, 1600mhz (PC3-12800), 1.5v, Non-ECC Unbuffered. That shouldn't be too hard to find.
