What SSD did you put in? What make and model?
Samsung 860 EVO V-NAND SSD (500GB)
And just to confirm, that’s the only drive is the system?Samsung 860 EVO V-NAND SSD (500GB)
That's correct.And just to confirm, that’s the only drive is the system?
Cool, thanks.That's correct.
Cool, thanks.
So I would run a chkdsk from the windows installer via method 4 here on the SSD:
How to Repair Hard Drive Error with Windows 10 CHKDSK Utility? - MiniTool Partition Wizard
Windows built-in disk repair tool CHKDSK can check and fix hard drive errors it detected. Check this post to see how to use it to repair hard drive Windows 10.www.partitionwizard.com
The command you want to run (make sure you're on the drive and not on the default x: is "chkdsk /f"
No worries, all the bestThanks for your help so far. I'll have to do this when I get home. I'll provide an update later this afternoon. Thanks again
Cool, thanks.
Nothing to do with the problem itself but...that RAM configuration is very odd Don't think I've ever seen a desktop or laptop supplied with 2 sticks of RAM of differing sizes
