It's arrived 3600x 3070 GPU
I just ordered and assume the good team at PCS know what they are doing. I tend to avoid stuff like this, as I'll watch it. Panic, remove a screw, screw it up and then be on the forums like 'So I broke it....' crying meme
i reckon they do as well so wouldn't worry over it
BT81
I just replaced the standard 3 pin NZXT case fans for x2 noctua chromax fans.
There are indeed quieter. Though it turns out, the noise that has been bugging me. Is the AIO pump. Facepalm emoji
I have to say, the cable management on the PC was second to non, it was the first time I removed the back panel. I have of course undone all their good work, as the cables on the new fans are so short, I've run them round the front....
One thing of note, the AIO doesn't appear to be plugged into the correct section on the motherboard. I'll investigate further. I'm sure it is right.
Anyway. I 'modded my first PC!' winner
