Keyboard "jumping" problem...
giorgio
I noticed while gaming, but the problem is still when I use FB chat, or notepad, or whatever: the pointer go back, or up/down, like if I used the arrows, but I don't...
It could be really a mess, especially while gaming, or fast chatting...
Someone with my same problem?
Christof
Try fn+f1 to disable the trackpad and then type a couple of lines. I thought I had the same problem but it's just overly sensitive - a gnats fart will set mine off....
giorgio
Ok, the problem was exactly the trackpad...
Now, should be possible to get it less sensitive, or just disable it when it's possible to use an external mousepad?
vanthus
Member Resting in Peace
Should be a keyboard shortcut to disable trackpad,try Fn + F1. or Fn + escape,
failing that check the manual on supplied software disk.
