Monitor Help
vanthus
Member Resting in Peace
Please can you link me the DVI cable that will work with the monitor?
Depends on the type of DVI ports you have on the monitor and graphics card,DVI-I (Single Link),DVI-I (Dual Link),DVI-D (Single Link) or DVI-D (Dual Link)
A DVI-D (Single Link) cable would be safe to go for as it would fit any of the above ports.
Generalkenz
Aoc 21.5" widescreen led tft
Does the AOC 21.5" WIDESCREEN LED TFT come with the DVI cable. I bought AOC 21.5" WIDESCREEN LED TFT just now on pcspecialist. Also, is it a good monitor for gaming. One more thing, what other cables has it got?
mandythesim
I would also like to know the answer to this :D
