thomasCarlier780
Here you go...
Thanks
Thanks
You're right, my bad, I wasn't seeing the 150W, that would be the correct charger for your spec with the 1660ti.The Optimus Pro comes with a choice of 150w or 180w adaptors....your spec list shows you opted for the 150w one and the picture above confirms you received a 150w one. Unless I'm missing something, 150w should be fine otherwise it wouldn't be in the configurator?
You can't select a 2.5" SSD, it gives a warning when you try to proceed.
Ok, so it's not the charger.
Next thing to try is when the screen goes black, shine a torch or something onto the screen and see if you can make out any of the text or desktop.
