Need Help With Gaming Rig
nanetorg
Hello everyone. I need help buying a computer. I do not want to pay more than 1000 pounds, best if its less than 900:) What im looking for?
Not looking for a super computer, I just want rig so I can play GTA IV for the full detail and in the WoW in Ultra :) Here is the specification of what I choose, ask for advice, i dont want to overpay.
For the moment i have AMD x2 2,7Ghz, 2GB ram 800Mhz and gf7900 GS;
Acer H233Hbmid Black 23" 5ms HDMI Full HD 1080P Widescreen LCD Monitor 300 cd/m2 40000:1 (ACM).
This is the spec i chose:
CORSAIR GRAPHITE SERIES™ 600T GAMING CASE ***NEW***
AMD PHENOM II X6 1090T (3.20GHz/9MB CACHE/AM3/) - (Special Offer)
Free Item
FREE STORMRISE Game (RRP: £29.99) with any AMD® Phenom™ II X6 Processor!
ASUS® M4A89TD PRO/USB3 : DDR3, USB 3.0, SATA 6.0Gb/s, CrossFireX
1GB ATI RADEON™ HD 5870 PCI EXPRESS - DirectX® 11, Eyefinity 3 Capable
Memory - 1st Hard Disk
640GB WD CAVIAR BLACK WD6402AAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
1st DVD/BLU-RAY Drive
CORSAIR 750W TX SERIES (TX750) 80+ ULTRA QUIET PSU (£88)
COOLIT ECO A.L.C (ADVANCED LIQUID COOLER) (£59)
Network Facilities
Price: £1,018.00 including VAT and delivery.
What i could change? Processor? Graphic card? Ill need the morherboard (for later upgrade) and a case (its just great looking)...
Thanks, George.
Tom DWC
It looks fab but to save some money, remove the watercooler (if you're not overclocking) change the processor to a quad core (the hex core will make no difference in terms of frame rate) and add the larger capacity Caviar Black.
nanetorg
I was thinking about change processor to x4 but there is just 30 pounds difference... same as cooler, 30 pounds from Triple Copper Heatpipe Cooler...
Sleinous
not question of price really. And that makes £60 u can spend on upgrading psu to incorporate a second 5870 in xfire.
