Well, I'm back. With the same problem as previously in the year (see my previous two threads 12-01-15 https://www.pcspecialist.co.uk/foru...-sys-BSOD-Desktop-and-Browsers-malfunctioning and 05-06-15 https://www.pcspecialist.co.uk/foru...g-Wireless-Card-suspected&p=327488#post327488)
I'm going to try to keep this as readable/accessible as possible, since there's a lot to say. Please bear with me. :sweatdrop:
- The problem that started in 01/15 was sudden and seemingly random.
- My PC had been working fine since I got it 08/14, and then one night I started getting problems and couldn't connect to the internet properly.
- I couldn't figure out what it was, went back to Uni where it worked fine with a Wired Connection, came back home 06/15 and the problem returned when I started using Wireless again.
- It seemed that all I needed to do was to return the card (ASUS PCE-AC68) to PCS and they would replace, and that would be the end of it. They weren't able to replace it, so they refunded it. I had already switched to a
Wired Connection by then and had other things happening, so this got put on the backburner.
- I recently bought a replacement card from Amazon (same card, ASUS PCE-AC68) and everything seemed fine. Unfortunately the problem returned after we had two strange power cuts (off and back on instantly). My PC
is plugged into a power strip with Surge Protection, and everything else is fine. I see this as a coincidence, and rather that it was just a matter of time before the problem returned.
Unfortunately I can't just stick to a Wired Connection. I share my accommodation with my Landlord, and they don't want a wire trailing downstairs to the router, albeit tucked out of the way. Either way, the card should be working without problems, which is what I want to fix. I've done some troubleshooting of my own and think I might have the answer, but I'd be a fool not to ask for other opinions and share the problem in more detail.
So what exactly is the problem?
- When using a Wireless connection (seriously, Wired has no problems whatsoever) my computer can freeze (temporarily), it can BlueScreen, programs can become unresponsive (temporarily), and the Browser tabs load
slowly (though eventually they load). My Download speed is fine, and the Wireless signal is good. My CPU is not getting overloaded, nor is my PC using too much Memory.
E.g. If using Chrome, I may have Tweetdeck open, with Twitch also open, maybe I'm also checking various other Social Media. The pages load slowly, and if they need to load more (scrolling) that is also slow. The
browser is likely to become unresponsive, too. If Twitch is open because I'm watching a Twitch stream, it'll likely start buffering and the connection will be lost.
E.g. If using Windows Media Player whilst using Chrome, the music can stop (though the progress bar continues, though it stops to wait for the music to catch up once it resumes) and WMP can become unresponsive.
Usually Chrome's tabs are loading slowly and it is likely that Chrome, along with everything else (Desktop, Windows Explorer (file browsing), is also unresponsive or becoming unresponsive.
E.g. If playing a game, it can freeze for a short period before resuming, though this is frequent and frustrating. If watching a Twitch stream at the same time, it is likely buffering or the connection is being lost
completely, with Chrome becoming unresponsive for that short period, before becoming responsive again.
As soon as the Wireless adapter is disabled, and Wired adapter re-enabled, everything works great (well, not after the most recent re-installation of Windows 7, but I'll detail that shortly).
- So what have I done/tested?
- Tested different Browsers > It happens regardless of whether it is Chrome or IE, and only happens with a Wireless connection
- Removed Avast in case of a conflict > This did nothing; the problem persisted. (So for now I reinstalled Avast)
- Tried a different Wireless card? > I had an old WLAN PCI 54Mbps wireless card lying around. My PC couldn't detect it, and since there's no brand to it, I doubt I could find a driver. So this remains untested.
- Tried a different Wireless card of the same kind? > Yes, the original was sent back to PCS, they refunded it. I eventually bought a new one but it too is causing problems (the same as before). I doubt it too is faulty.
- Reinstalled Windows 7 > Multiple times. Only once since getting this new card. As soon as I installed Chrome to test the Wireless, the problem was there (barebones, just Drivers, maybe f.lux and Avast too).
- System Restore? > Probably did earlier in the year. Seems pointless now since reinstalling Windows doesn't really fix the problem, so why would a System Restore? The problem came back immediately.
- Disabled a Wireless Setting "Turbo QAM" > This didn't do anything to help. After researching, it really just boosts speed and signal or something, so not surprised.
- Changed slots on the MB > This didn't help either. The problem occurs when using the Wireless card, regardless of which PCI-E slot it is in.
- Checked for Viruses > So many times, mostly earlier in the year. There's nothing found by either Avast or Malwarebytes.
- CHKDSK > Quite a few times, mostly earlier in the year, but once since reinstalling Windows recently. It found no problems on either my SSD (has the OS and generic programs) or my HDD (storage, game
installations).
- Checked the RAM? > Yes, mostly earlier in the year, though. 7 Advanced passes (or whatever) quite a few times. None recently, but they found no problems, which is why.
- Checked Event Viewer > Yes, and there are some results there that seem to point to the/a problem, but I don't quite know what I'm reading. Will share shortly.
- Examined the Wireless Card settings > I had a look, and found nothing that seemed out of order, but there is one thing maybe, so I'll share that shortly.
- Googling it? > Yes, which came up with some results that I think point to the problem, but not a fix outside of getting a refund and buying a different Wireless card.
[I hit the character limit >.< so see the second post below for the rest]
[Formatted to a 1080p resolution, sorry if this looks janky on other resolutions]
installations).
