New P.C build help
Johnny b
Hi i need some help deciding whats best for a video editing/gaming P.C ill be doing HD recording using a hauppage HDPVR, editing using Adobe after effects sony vegas Cinema 4d,Gaming to.
Specs iv'e chosen so far:
Intel® Core™i7-2600k Quad Core
ASUS® P8Z68-V: USB 3.0, NVIDIA®SLI™, ATI®CrossFireX
8GB KINGSTON HYPER-X GENESIS DUAL-DDR3
1GB NVIDIA GEFORCE GTX 560 Ti
120GB INTEL 320 SERIES SSD
500GB WD CAVIAR BLACK
TITAN FENRIR EVO EXTREME
CORSAIR 850W TX SERIES
I would of preferred Intel SSD 510 120GB but i cant stretch my budget any further,will the intel 320 perform good in my motherboard? is there a big real world difference in performace between a sata 2 ssd and a sata 3 ssd.would i be better off getting two 500GB WD hdds on Raid0 ? Will i benifit from using ssd over a dual hdd raid setup?
Also any help on a good case to get my budget is £79
Thanks for Any advice in advance
Wozza63
Biblical Poster
£79? Typed wrong... I think by the sounds of it that you don't need an ssd although with that board you have an option to choose a cache drive which may be better for your budget, a gtx 570 gfx card may also be a smart investment if you can. You also do not require the 'k' version as that is for over clocking, no benefit over normal i7 other than that
The Titan fenrir is also not really required
Because you probably won't be over clocking and the triple copper should be fine, the Titan is also massive and most of the time it blocks your side fan, then the rest of your board will suffer
The 1600 ram is also not required, 1333 samsung ram will do you fine
Frenchy
Id actually say that the SSD will deffinately help, especially if you put your main HD video you are editing on the SSD, from the sizes of files ive seen in the past this could easily be bigger than the total size of ram and therefore having on an SSD will increase swapping speed (speed at which data swaps between ram and hdd) massivley.
RAM wise, id actually say stick with the 1600 again because of the nature of the work you are doing. I wouldnt go any higher than that but I also would be careful about dropping to the 1333.
As for everything else wozza said, I agree about the 570 is you want a bit more gaming power, although the 560 Ti is still a really good card. And unless you plan to overclock deffinately drop the k varient cpu.
Johnny b
First off thanks for your reply, I men't £79 budget just on a case my budget for the whole build is £1,220, the main thing i wanted to know was if the intel 320s would perform better than a dual hdd raid0 setup, i am planning on overclocking not much though.I don't really game much i play xbox360 way more i want it mainly for HD editing and recording also 3d animation. Thought the gtx 560 ti would be a good choice not the best but still good for editing plus a bit of gaming. Any suggestions?
Wozza63
Biblical Poster
Well I think it's the 690 that's £79 and it's got good cooling etc
If you are an experienced over clocker you may be ok with the normal i7 still as it can still be over clocked it's just a bit harder and it doesn't go much past 4ghz
Yes the Ssd should perform much better than RAID
Johnny b
Thanks for your kind advice that cleared the ssd issue up i was having. How would i drop to 1333 i don't understand, how do i prevent that from happening? i will be overclocking so ill keep the k ill probably upgrade my graphics at a later date, as it doesn't play a bit role in editing stuff apart from apps that support cuda and 3d animation, so gtx 560 ti should be good enough. :)
Johnny b
Do you know how many fans you get with that case, is the 922 better its says it comes with three fans.
Im not an experienced overclocker that's why i thought the 2600k would be good because its easier i want to run @ say 4.5 not to sure yet thanks man.
Wozza63
Biblical Poster
Why don't u just buy a pre-overclocked processor from PCS, they aren't that much more expensive and the clock for i7 will be 4.8GHz
If you are op dr locking then you will need the 1600 ram it doesn't even give you the option for 1333 on the overclocked section
I don't know how many fans you get but I think they give you a front, back, top and 2 small side fans, I can't check at the moment my iPad doesn't let me scroll across to the other cases I'll find out as soon as I get my laptops Internet working
bg92
Expert
Go for this if you want an overclocked pc
COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE
Overclocked CPU
Overclocked Intel® Core™i7-2600k Quad Core (3.40GHz @ max 4.80GHz)
ASUS® P8Z68-V: USB 3.0, SATA 6GBs, NVIDIA®SLI™, ATI®CrossFireX
1.25GB NVIDIA GEFORCE GTX 570 - 2 DVI, HDMI, DP - 3D Vision Ready
Memory - 1st Hard Disk
750GB WD CAVIAR BLACK WD7502AAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
SSD CACHE DRIVE
20GB INTEL® SSD 311 SERIES - CACHE DRIVE FOR SYSTEM / 1st HDD
1st DVD/BLU-RAY Drive
CORSAIR 650W TX SERIES (TX650) 80+ ULTRA QUIET PSU (£72)
TITAN FENRIR EVO EXTREME HEATPIPE CPU COOLER (£39)
ARCTIC COOLING MX-3 HIGH THERMAL CONDUCTIVITY COMPOUND (£9)
Network Facilities
Quantity
1
Price: £1,226.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/intel-1155-overclocked/
Or this if you don't want an overclocked and are not intending to overclock
Intel® Core™i7-2600 Quad Core (3.40GHz, 8MB Cache) + HD Graphics
8GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (2 X 4GB)
SSD CACHE DRIVE
Network Facilities
Quantity
1
Price: £1,167.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/intel-sandy-bridge-pc/
Johnny b
Do you think this would be a better choice
Overclocked CPU
500GB WD CAVIAR BLACK WD5002AALX, SATA 6 Gb/s, 32MB CACHE (7200rpm)
SSD CACHE DRIVE
CORSAIR 750W TX SERIES (TX750) 80+ ULTRA QUIET PSU (£86)
Network Facilities
NO OFFICE SOFTWARE
Quantity 1
£1,228.00 inc VAT
Or this
Overclocked CPU
ASUS® P8Z68-V PRO: USB 3.0, SATA 6GB/s, NVIDIA®SLI™, ATI®CrossFireX™
1GB NVIDIA GEFORCE GTX 560 Ti - 2 DVI,HDMI,VGA - 3D Vision Ready
120GB INTEL® 320 SERIES SSD, SATA 3 Gb/s (upto 270MB/sR | 130MB/sW)
2nd Hard Disk
500GB SERIAL ATA 3-Gb/s HARD DRIVE WITH 8MB CACHE (7,200rpm)
Network Facilities
NO OFFICE SOFTWARE
Quantity 1
£1,208.00 including VAT and delivery.
Which one do you think would be better for what i need
