nova 1TB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W) not working
dylgri
should i try and update the driver like this ?
dylgri
sorry am i clicking on the bottom image to delete the drive ?
dylgri
it woudnt let me delete it at the start just came up with these errors
dylgri
in the drive it still showing my old folders i had in it and i carnt delete them. The folder steam games 1 i just created it to try and install gtav and it still coming up with disk drive error
You’ll need to reinstall the games from scratch.
I would also do a full scan with malwarebytes to check for viruses.
Are these games legitimate or torrented?
So you're saying that when you right-click on the D: drive in Disk Management and select Delete Volume, you get that Incorrect Function error?
If that's what's happening you need to phone PCS because your SSD is probably faulty.
maha
The SSD may have moved, open the chassis, check the screw if it moves or not and in the worst case remove the SSD and put it back in its place.
I had it one this on a laptop and everything went ok after.
If it still has problems, call PCS to explain the problem, the SSD may be faulty
That was a good old slog that one. Some good trouble shooting though so cudos to the op for managing to get through all the instructions :D
As above, I would shut down fully and re-seat the m2 drive. It's a last ditch, if that doesn't allow you to carry out the commands then it's a faulty drive (at best) or faulty motherboard (at worst). It's most likely the HDD though so hopefully PCS will have it sorted in no time.
I don't think you need to wait to Monday to call though. I believe they are open today :)
