egorgeg
You sound like the man who jumped off a ten-story building. Every floor he passed on the way down the people inside heard him saying "so far, so good!"...
Not sure what to make of that lol
It's just my way of highlighting the fact that it's going to take you a while to trust your PC again. For a short while you'll be waiting for it to fail. But that will pass.
Hi Egorgeg, I just wanted to say your not alone with the strange repair/technical support. I recently returned my computer back to PCS and after 3 weeks of work it was returned in the same state as before. To be even more confusing the tech had said they had enabled functionality when they had just brushed over the problem. I can completely understand your frustration and just wanted to let you know your not alone in this.
However just about 10 mins ago my GPU usage jumped to 70% for no reason at all, temperature rose to around 75-78 Degrees and I heard an annoying squealing noise coming from it (I checked in the case and was clearly coming from GPU). I thought it was Coil Whine but I have no idea what it sounds like. Windows automatically switched off aero, and my CPU also started playing up. Usage ramped up to 60-70% on all cores, temperatures rose to 45-50 Degrees. RAM usage was at 19% which is normal.
1) Search for Task Scheduler via Quick Search, or Start / All Programs / Administrative Tools / Task Scheduler
2) Navigate down into Task Scheduler Library / Microsoft / Windows / Maintenance
3) Right-click on "WinSAT" and choose disable/delete.
That's all that was, nothing to worry about.
It's the Windows System Assessment Tool, it's the same thing that runs when you update your Windows Experience Index. If you take a look at yours (Right click Computer > Properties > Windows Experience Index) it will say it was last run last night. I was having the exact same thing happen every Saturday night.
