I received one of your Xenon laptops for £700 for Christmas and something's gone badly wrong. To cut a long story short, the laptop is now at the stage now where when I boot it up, it just says 'Invalid partition table'.
From what I can see, somehow the hard drive has gone back to a non-formatted(?) state, so I need to re-format it before I can re-install windows. So I go to format the hdd and get the message 'You need to format the disk in drive C: before you can use it, do you want to format it' and after clicking 'yes' I get the following problem - 'Windows can't format C - Check to see that the disk and drive are connected properly, make sure that the disk is not read-only, and then try again.'
So how do I check or change it if it's read only or how else can I format it so I can install windows?
Any help is much appreciated.
Chris
Chris
