Hi there, I've only today got my new Desktop and within an hour of it being turned on it just shuts off with no warning, noises etc and won't turn back on at all. I'm not completely computer savvy but since everything seems fine inside and the only issue is it won't turn on I'm guessing its a PSU issue. I've used different sockets, different cables and no results at all. The tower wasn't modified in anyway and was working perfectly until it suddenly shut off. If anyone has any advise, anything I may not have done to cause this or how I can fix it I'd really appreciate some help. Specs are posted below, Thanks.
Specs:
Processor (CPU) Intel® Core™i7-2700k Quad Core (3.50GHz, 8MB Cache) + HD Graphics
Motherboard ASUS® SABERTOOTH P67 (NEW REV 3.0): USB 3.0, SATA 6.0GB/s, THERMAL ARMOR!
Memory (RAM) 8GB SAMSUNG DUAL-DDR3 1333MHz (2 X 4GB)
Graphics Card 2GB NVIDIA GEFORCE GTX 560 Ti - 2 DVI,HDMI,VGA - 3D Vision Ready
Memory - 1st Hard Disk 2TB WD CAVIAR GREEN WD20EARS, SATA 3 Gb/s, 64MB
Memory - 2nd Hard Disk 2TB WD CAVIAR GREEN WD20EARS, SATA 3 Gb/s, 64MB
1st DVD/BLU-RAY Drive 12x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW
Memory Card Reader INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply CORSAIR 850W ENTHUSIAST SERIES™ TX850 V2-80 PLUS® BRONZE
Processor Cooling SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE INTEL CPU COOLER
Sound Card Creative Sound Blaster® Audigy™ SE
Network Facilities 10/100/1000 GIGABIT LAN PORT
Specs:
