Another question for the experts!
This one is a little more difficult to calculate I think but if you can answer it I'd be highly grateful!
Ok, so I want to know if I'm using the upper limits or even going over my psu (850w corsair)
The spec I have in mind is this (NOTE I've manually changed some sections to display what the setup will be when I fit it)
Case COOLERMASTER HAF 932 FULL TOWER GAMING CASE (£120)
Overclocked CPU OverClocked Intel® Core™i7 Six Core Processor i7-970 (3.2GHz @ max 4.0GHz)
OC Settings CPU RATIO: 20
BCLK FREQ: 200
DRAM: 1603
UCLK: AUTO
CPU VOL: 1.325
QPI/DRAM: 1.35
DRAM BUS: 1.64
HYPER THREADING: ENABLED
SPEEDSTEP: DISABLED
Motherboard ASUS® P6X58D-E: DDR3, USB 3.0, SATA 6.0GB/s, 3-Way SLI
Memory (RAM) 6GB KINGSTON HYPER-X T1 TRI-DDR3 2000MHz, X.M.P (3 x 2GB KIT)
Graphics Card GeForce GTX 480
Memory - 1st Hard Disk 1TB SERIAL ATA 3-Gb/s HARD DRIVE WITH 16MB
2nd Hard Disk 2x 500gb
RAID NONE
1st DVD/BLU-RAY Drive DVD RW/burner/reader
2nd DVD/BLU-RAY Drive NONE
Memory Card Reader INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply 850w corsair
Processor Cooling TITAN FENRIR EXTREME DIRECT TOUCH COPPER CPU COOLER (£39)
Thermal Paste ARCTIC COOLING MX-3 HIGH THERMAL CONDUCTIVITY COMPOUND (£9)
Sound Card ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Network Facilities ONBOARD 10/100/1000 GIGABIT LAN PORT
Operating System Genuine Windows 7 Home Premium 64 Bit
Keep in mind I'm gonna have the whole thing overclocked and using the most of it, this list also isn't accounting for the fans but I don't thing they make a large impact
I'm sure it's fine but getting mixed feedback on psu watt calculators I'd like some assurance.
Thanks for any help, just want to make sure I get every piece of hardware right so that nothing breaks!
BCLK FREQ: 200
DRAM: 1603
UCLK: AUTO
CPU VOL: 1.325
QPI/DRAM: 1.35
DRAM BUS: 1.64
SPEEDSTEP: DISABLED
RAID NONE
