You could but it could be pretty battered with a bit of noise lol. not sure how much air it will take in as the bottom has room for air to be taken in but not alot since the gap aint "big" unless you can counter that by taking out the filter which slightly override that problem but in return, you will have dust getting into your case.
Sweet, I want one lol
not really, its justt annoying that you have to take the bottom casing off the case frame to screw the fan in properly lol where the 140 fan, you can just clip it in; it can be screwed in too but same procedure with the screws if you want it fitted properly.
that will do fine the bottom fan you just hook up to the fan controller.
