I just configured an AMD desktop system on your web site today (reference no 2623784) but I have a few questions as follows that I need resolved before I am happy to proceed with the order:-
I am sorry but I dont immediately know how to post my configuration details here but hope that the quote no will suffice.
1. I have three items in my existing home desktop system that I am looking to install myself after the system has been delivered. These items are a 2.5 inch Crucial 2TB SSD model no CT2000MX500SSD1 (currently mounted in a 3.5 drive caddy), a NVIDIA Geoforce GT730 graphics card and a Microsoft Wireless Keyboard & Mouse.
2. The SSD will require power and data cables, it would be convenient if cables were pre-installed as part of the system to support installation in a suitable 3.5in drive bay. I assume that there would be a charge for this service, please advise.
3. I don’t have the budget to spend the kind of money that it would take to include any of the high spec graphics cards that are offered as part of your configurator. I already own the NVIDIA GEOFORCE GT730 graphics card as part of my existing system and it has proven perfectly capable of running most if the PC games that I want to play. It requires a PC power supply of 300 Watt or greater PC with a minimum of 20 Amp on the +12 volt rail. It is designed to operate in a PCI Express, PCI Express 2.0 or PCI Express 3.0 compliant motherboard with one graphics slot. Power draw is a modest 40 watts according to specs I have found online. Please can you confirm that I can use this card within my intended configuration.
4. I have included an AOC 23 inch monitor within the system and I would like the system delivered and tested with that configured to use integrated graphics and DVI-D monitor connections. This will facilitate my switch to my GT730 graphics card which I currently use with DVI-D monitor connections.
5. How do I communicate the above requirements to the PCSPECIALIST build team that will build my system ?.
Many Thanks
Bob
Many Thanks
Bob
