samcol
So some of you may have seen the issues I've been having lately.
After 3 weeks and one day, PC would make an interference sound (a buzz) and skip a load of frames intermittently, making all tasks bloody hard to do (don't even think of playing a game).
Go to boot it up on Sunday and Windows doesn't display after the initial splash screen (though the BIOS is accessible), just a blank screen with a signal, but no cursor / image.
Diagnostics over the phone and we come to the conclusion the Palit 970 Jetstream GPU is to fault - a stock 970 gets sent out as a replacement.
Upon installing the new replacement GPU, the first boot up worked, so I decided to update the driver. Not being entirely confident in the PC at this point I tried a shutdown and restart and 'Waddayaknow', I have exactly the same issues - After Splash / BIOS screen Windows 8.1 does not seem to display - black screen, but when pressing random keys as everything is powered on and lit up, I get some noise (for example incorrect password sound), and the off chance that it does boot (1/10 restarts) the buzzing / frame skipping returns, even on the simplest tasks such as browsing Chrome and changing the volume via the taskbar. It has even booted up then turned black while I was typing my password. 99% of the time windows doesn't display, but as I said, absolutely every piece of hardware / peripheral is lit up and working, and I can get a sound. It is also worth mentioning i get the single beep from the motherboard upon powering on - which I believe means it is fine, and there are no error reports.
Here is everything I have tried - Did not work means Windows did not boot:
Removed all peripherals and tried without and with again - Did not work
New Graphics Card - Did not work
Complete Un-installed / Re-installed of drivers (LOTS) - Did not work
Swapped Graphics Card from PCI-E 16x slot to PCIEx8 slot - Initially worked, but restarted and did not work
Go to BIOS and start through there - Initially worked, but tried again in same way and did not work
Lots of restarts - 1/10 worked, but then had buzzing / stuttering - Does not work
Removed Graphics Card and used motherboard's Integrated Graphics (Same DVI Cable) - Worked
I haven't been able to re-install windows (no disc-drive) but as I can access it through Integrated Graphics I don't think that's the problem.
This is getting extremely frustrating, especially as the PC has probably been on for less than 24 hours since I received it 4 weeks ago.
Any suggestions on what more I can try, and I will be extremely grateful. I'd like to exhaust all possible options before sending off for an RMA. And I REALLY don't want to refund this because this is my first PC, and I saved for a damn long time. This even came before my Girlfriends 21st, which I might regret :|.
PC Specs are:
Corsair 750D Full Tower
Intel® Core™i7 Quad Core Processor i7-4790k (4.0GHz) 8MB Cache
ASUS® MAXIMUS VII RANGER: PCI-e 3.0, SATA 3.0, USB3.0
16GB KINGSTON HYPER-X BEAST DUAL-DDR3 2133MHz X.M.P (2 x 8GB)
4GB NVIDIA GEFORCE GTX 970 - 1 DVI, 1 mHDMI, 3 mDP - 3D Vision Ready
1st Hard Disk
120GB Samsung 840 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 410MB/sW)
2nd Hard Disk
2TB WD CAVIAR BLACK WD2003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
CORSAIR 650W CS SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Corsair H80i Hydro Series High Performance CPU Cooler
Genuine Windows 8.1 64 Bit - inc DVD & Licence
Keyboard & Mouse
Corsair Vengeance K70 Fully Backlit Gaming Mechanical Keyboard
Mouse
Razer® Deathadder Gaming Mouse
Thanks Guys.
PC Specs are:
1st Hard Disk
2nd Hard Disk
Keyboard & Mouse
Mouse
Thanks Guys.
