I am only having a laugh. LOL. Everyone is entitled to their own opinion.
PS I didn't just remove the edit. I removed the whole post as it became useless spam.
The Eco is old. It still does a good job. I have only heard of a handful bursting. I don't think though that I have heard of one bursting after the first few weeks though. As I stated in an earlier post they seem to be fine after a few weeks. Perhaps a manufacturing problem.
I am not overly familiar with the H100 although I have seen plenty going around. I have just read up on the performance and it looks good. Although if I had one I think I would change the stock fans.
I was given a Eco II a few days ago. It is the FB 45mm rad model. I was thinking about selling it (not plugging it) but I was also thinking of taking it apart and messing around with it adding a water / water heat exchanger and using the supplied 150 litres / hour pump and doing some tests with various other cooling methods. Like submerging the radiator in running water. Undersoil heat exchangers. etc. I have done some calculations and this could be an excellent efficient green way of cooling. All well and good but without checking it out would be very expensive. The Eco II would be perfect as a base for this. If it works well then perhaps upgrading and going full scale custom loop.
you could try one of these - http://www.amazon.co.uk/Akasa-AK-CB...=1374790989&sr=8-6&keywords=molex+to+3pin+fan
it connects four 4 pin fans, two run at 12v's and i think the other two run at 7v's.
Those fan connections look different to the one I took a pic of. They seem to have a shroud round them whereas the one I have had the 3 pins un-shrouded
yeah, it wont make a difference as long as the fans are 3pin connections.
Ah, that's good to know.
Daft question but if I connect 2 fans up to that adapter, will it cut down the voltage to 6V each, thus reducing the fan speed?
As someone who likes to busy themselves with small alterations to my PC when my budget doesn't allow for a big upgrade, I love things like this. Good for you. I've ordered some interior LED strips for the inside of my White Dragon Rider. Swoosh.
looks good. A good mod may be tom_gr7 . Pretty good cpu entry level liquid cooler.
Got my wrist slapped for give some buying advice not related to buying direct from pc specialist.
I wouldn't mind some for my case maybe, do they just connect to one of your PSU cables? And how do you attach them to your case? Just tie wraps or something?
Some run off of a molex connector, the same used for your fan, and I believe the NZXT ones comes with a PCI slot, which fits into the motherboard beside your gpu and allows for more control.
http://www.nzxt.com/product/detail/101-sleeved-led-kit-case-accessory
I have some of these in white. It just fits into the backplate, nothing actually goes into the mobo. It just has an on and off switch on it, and a slidy thing which goes from low, med and high brightness.
They're good, but ideally i need another set cause the case is quite big
The other ones should be here any day now too eh? Should be good fun. I'll make a wee vid for you. It will also get me viewing figures on youtube.
