RMA Returned - Cooler position question
B4zookaw
So what you're saying is there is not a third grouping of holes at the top of the case, under the lip?
Madrugar
I would have hoped that if the Corsair H115i wasn't suitable to be installed correctly on my case then PCS might have mentioned this prior to signing off and returning my RMA.
I would take the fans off the roof and attempt to install there mate, it's definitely worth a try. It's a pain mate I know but be good to rule it out, certainly not ideal to have it where it is now
barlew
Godlike
I agree id deffo give the top vent a go.
If the roof doesn't work I would probably just mount it with the 4 screws at the higher level...... if it annoyed me I would just drill holes.
Me too but you've seen what I've done to my case so I'm not sure I'm a wise person to take DIY advice from
