Sabertooth P67 Mobo w/ Thermal Armor compatible with Watercooling?
lloydehhh
Hey all.
Im just wondering, is the Sabertooth P67 Mobo compatible with watercooling? As the plastic "Thermal Armor" covers the CPU, I thought this may be a a limitation. Any help is appreciated :)
Meds
When you say water cooling, do you mean a custom loop with your own CPU Block, Pumps etc? Or do you mean the self contained liquid coolers like the CoolIT ECO?
Gorman
The plastic covering for the board does not obstruct the fittings for any cooler suitable for that socket.
As far as we know.
samm2010
I believe that it is but i would only cool the CPU and loop back for GPU's there is a panel where the northbridge is on older motherboards that you can unscrew and place a 50mm assistant fan so you still get the benfits from the thermal armor. :turned:
