There may be a switch for turning it on or off.So i received my new pc today but no led coming from the fan? The case is a NZXT Phantom 410, i thought it came with an LED fan as stock? But nothing in my pc is lighting up? Can someone help me with this please?
As you've just received the PC,probably best give tech support a call.My NZXT Phantom 410 led on the fan is not on for some reason? (Is there a switch?) Also the pc keeps freezing for like 5 - 10 seconds then kicks back to life.. any idea's or comments would be appreciated!
call (0844 499 4000)
Monday - Friday 9am - 5pm (Saturdays 9am - 1pm).
View waiting times http://www.pcspecialist.co.uk/call-waiting/
Yeah fitting ram is very easy Just remember to switch off the PSU, unplug it and ground yourself by touching a bare metal part of the case before you do anything
You could try one ram stick at a time to check if one might be faulty.So the freezing is back, i unclipped the RAM and clipped it back in again and it seemed to have fixed it but now it's freezing again and the computer hasn't moved from it's spot. Any idea's on what else might be causing this?
It is bit unfair to make a comment on how rigorous testing/quality is without knowing the % of systems that experience issues. From my own experience I found technical support extremely helpful.It seems a common theme on these forums regarding new machines delivered and not functional as expected, I thought PCS had a rigorous testing procedure? Apparently it is not as rigorous as one would hope anymore since PCS became more well known. To many machines being made and not the staff to test them properly this looks like.
Agree with Everon, try to contact PCS on Tuesday.Does any PCS employee's read these forums out of hours? Really getting annoyed with this now.
I seriously doubt that a memory stick could be dislodged via transit as the force required to do that would smash the machine totally.
You have a faulty product, it is within the return time so make use of that. You wouldnt go and buy a £1000 tv and accept it if it was broken on delivery and be expected to make repairs on behalf of the company you bought it from, so why do it now?
Phone PCS on Tuesday (bank holidays sigh) and get it returned for diagnostics.
The forums aren't officially supported by PCS, the staff do sometimes frequent them out of hours but understandably nothing is guaranteed, best to get in touch through the official channels.
@ToxicFox It sometimes used to be the case that in order to place the protective bag inside the PC (I see you have a large chassis) the fan header occasionally had to be disconnected to fit it in, depending on the placement. I'm going back a few years here and the case line-up has changed significantly but there used to be one or two where it had to be taken out for transit and reconnected user end.
Regarding the other problem maybe an RMA would be for the best. I know it's frustrating but better to wait a little longer and get the issue resolved properly.
I thought this but did not want to jump to any conclusion as i don't have the facts to do so but my reasons for doubting are: An LED Fan is included with the case as standard (NZXT Phantom 410) please correct me if im wrong but when i received my computer none of the fans had any LED's on them, Would this be PCS taking the LED one out for some reason? even so during testing they should pick it up, i know it seems a small problem to moan about but it makes me wonder if this was overlooked then what else was?
I spent over £1000 on this system and it certainly has not yet proven to be worth my money.
My wife bought me a Razer mouse and Keyboard for an early father's day present so cant wait to use them!
