Specs Check
Raawrzy
Should I consider getting a wireless router/ethernet? Ethernet might not be possible though.
Citrus_9
Expert
Ethernet already comes with a motherboard, but if you'll need wifi, then you just pick a Wireless Network Card Wireless Intel Wifi AX200 which also comes with a Bluetooth.
Raawrzy
Cheers. So would it be (at all necessary) getting an aftermarket cooler or ultimately useless, if no, suggestions?
JUNI0R
I guess £50 for the cooler? I'll try order asap once I get a respomse.
Prices have changed so much and there's likely things that we'd spend the money on over a cooler.
Could you give us a refresh of your most recent budget, what you'll be doing with the PC and what monitor you're using (make and model or resolution and refresh rate). Once we've got a build that we're happy with, I'd advise you order it ASAP, this process shouldn't take 2 months.
Raawrzy
Apologies. And sure, £1200 very max for the PC, 24 inch 144hz monitor MSI/AOC and I'll be using it for 1080p gaming (because of the monitor) and some general desktop use.
JUNI0R
Here you go
STANDARD AMD CPU COOLER
Standard Build - Approximately 15 to 17 working days
Price: £1,199.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/qRKyRF0dzJ/
Raawrzy
Just ordered! Thanks a lot, appreciate everyone's help as I was really uncertain at first, even though it's taken a while (yeah 2 months ;/) it's finally done. Thank you all. <3
JUNI0R
You're welcome, I'm glad we were finally able to get it sorted for you. Now the waiting game begins!
Citrus_9
Expert
Here you go
Nice build and 1 Pound for ice cream left :)
Raawrzy
So I'm planning on buying the G241, which has a 1.2 DP slot, would any 1.2 displayport cable be fine? Or is there a specific one you can give me to buy? Because I'd rather use DP over HDMI as most would.
