Specs Check
Raawrzy
Something I briefly noticed is that these 2 glow red but no warning has been given. Help? Is it a problem?
Ash_
Master Poster
Those parts are not currently in stock, but that doesn’t matter anyway, as they will almost certainly be back, before the build starts
Raawrzy
Heyo, just made this pec (below) and I'm wondering it it's alright and if it needs improvements. I don't want to drastically increase the price btw :)
Intel® Core™ i5 Six Core Processor i5-10400F (2.9GHz) 12MB Cache
ASUS® TUF Z490-PLUS GAMING WI-FI (LGA1200, USB 3.2, CrossFireX) - ARGB Ready
8GB NVIDIA GEFORCE RTX 2070
PCS FrostFlow 240 Series RGB High Performance Liquid Cooler
It's not well balanced and the GPU doesn't exist anymore? Is that one you already have?
What monitor are you pairiing it with, what resolution and refresh rate or make and model if you're unsure?
What do you use it for?
If you can post the full configuration as per below, then we can advise further:
Raawrzy
Oop- I meant 2060. Prob a 144hz Monitor maybe if possible? And mainly for gaming. I'll post the full spec tomorrow
Raawrzy
Heyo, just created a build and was wondering if I could improve this build? Could I decrease the price in anyway and make it like £50 cheaper ish? £1200 is my budget but I'm looking to buy a monitor as well (144hz and like 1080p?) so I don't want the PC to just be at the budget because I want to lower the price a bit, I'll be using it for gaming. Let me know if I can improve this :)
ASUS® ROG STRIX B450-F GAMING (DDR4, USB 3.1, 6Gb/s) - RGB Ready!
6GB NVIDIA GEFORCE RTX 2060 - HDMI, DP - VR Ready! (Not in stock)
CORSAIR 450W CV SERIES™ CV-450 POWER SUPPLY
PCS FrostFlow 240 Series RGB High Performance Liquid Cooler (AMD)
Standard Build - Approximately 14 to 16 working days
Price: £1,123.00 including VAT and Delivery
Unfortunately, it's difficult to improve things whilst lowering the cost. You really want to be spending the maximum of your restricted budget in order to cover yourself for future upgrades. We're certainly hoping that prices will get a bit more sensible come the summer, so if budget really is an issue my advice would be to hold onto your money for now, see if you can add a bit more to the kitty and then come back in a few months :)(y)
That's sound advice
Raawrzy
Heyo, I recently created the spec below and was wondering if I could improve it or save money in any way. I'm going to be using it for 1080p gaming, deciding between a 75Hz monitor to save money or just going with a 144Hz. Let me know if I can improve this and potentially save some money :). Should I go for a 3600 or a 10400f? This is the 3600 build.
Firefox™
Price: £1,158.00 including VAT and Delivery
JUNI0R
Firefox™
@ubuysa @AgentCooper Would a lovely mod be able to move their to a pre-existing thread?
@Raawrzy It's a lot easier for people to give advice if they've seen the full history of discussion behind the purchase. We can give you some guidance once the threads have been moved! Also once it has been moved, would you be able to add the configurable link at the bottom? Thanks!
JUNI0R
Firefox™
As has already been highlighted, Intel is a bad choice currently so I'd stick with the AMD build personally! If you're purely looking to save money. The Case can be swapped in for the cheaper and just as RGBey Lian Li 215 which is still a great case, the 3600 will be fine with the stock cooler and you could get rid of the thermal paste too. That alone would save £70. But I'd recommend investing some of that back into an RM850 PSU which will give you a more comfortable running PC and more upgradability options down the line (as you have a larger overhead for more powerful tech).
The 1660 Super is a currently great card and will comfortably run most games on a 75hz monitor with most games on 1080p high (Check out this review for benchmarks). However, if you were to lower your settings somewhat I'm sure you could get 144hz from a lot of games too. 144hz is a fantastic experience (I've heard) and once people switch they can't go back so I'd recommend going for a 144hz monitor for the games than can take advantage of it.
It might not keep up with all the releases for the next 5 years at super high graphics but it'll do a fairly comptient job for the next few years at which point an upgrade to a 1440p 144hz experience would be a great choice. You could use that saved money to go for a 2060 which would last longer and ofc give you a better experience, but the one that PCS has currently would take you over your (assuming) £1,150 budget by about £100.
When it comes to monitors, there's two we normally suggest for 1080p 144hz which are the MSI Optix G241 and the AOC 24G2U. Both can currently be found £200 online.
Raawrzy
Thank you! I'll look into all of these.
JUNI0R
Until you get the platform right there’s no point looking at storage, if you post your proposed build then we can advise.
@SpyderTracks OP did put forward a build above which I then made some recommended changes to. The price for theirs was £1,158 and they wanted to make it cheaper so I managed to get it down to £1,093. Spec is below.
For the budget I think the storage solution is decent, you could upgrade to a 1TB SSD if you plan to play especially large file games (GTA, COD, Warzone etc) , although that does raise the price back to £1,137. If you don't, the 512GB should be enough for Windows, programs and some smaller games. And a 2TB HDD is only £13 more for double the storage and 4X the cache and something I'd recommend considering (which you could also put your larger file games on, although load times will be slower)
ASUS® TUF GAMING B550-PLUS WiFi (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
CORSAIR 850W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
STANDARD AMD CPU COOLER
Price: £1,093.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/q0hngT3fn6/
