So I'm thinking of just upgrading my 2nd Hard Disk - the SSD (to the 240gb equivalent) and the wireless adapter (to a Killer 1202) (my original spec is at the bottom of the post)
I have two options: Send it off for upgrade, or get the stuff delivered to me and I do it myself
Of course, sending the laptop off for upgrade would take some time and be more costly. I was wondering how simple the upgrade would be if I were to do it myself or anything else it may entail.
Any advice would be appreciated!
Chassis & Display
Optimus Series: 17.3" Matte Full HD LED Widescreen (1920x1080)
Intel® Core™i7 Quad Core Mobile Processor i7-3740QM (2.70GHz) 6MB
8GB KINGSTON HYPER-X GENESIS 1600MHz SODIMM DDR3 (2 x 4GB)
NVIDIA® GeForce® GTX 660M - 2.0GB DDR5 Video RAM - DirectX® 11
Memory - 1st Hard Disk
750GB WD SCORPIO BLACK WD7500BPKT, SATA 3 Gb/s, 16MB CACHE (7200 rpm)
2nd Hard Disk
120GB INTEL® 330 SERIES SSD, SATA 6 Gb/s (upto 500MB/sR | 450MB/sW)
1st DVD/BLU-RAY Drive
Network Facilities
GIGABIT LAN & WIRELESS INTEL® ADVANCED-N 6235 (300Mbps) + BLUETOOTH
Battery
Optimus Series 8 Cell Lithium Ion Battery (5,200 mAh/76.96WH)
Power Lead & Adaptor
1 x UK Power Lead & 120W AC Adaptor
NO OPERATING SYSTEM REQUIRED
Chassis & Display
2nd Hard Disk
Network Facilities
Battery
