I have had this problem for about a month now and its driving me mad. Basically At random and recurring times all usb ports will disconnect and stop responding as in my keyboard and mouse. Its weird because its often when I start games or are in them but can happen at any time, it also happens a lot as soon as i log in or when I am just browsing. Every time it happens i have to restart my PC because they won't ever start responding again. A funny thing is Its only started happening about half a year into using my PC.
Some fix's i have tried to resolve this are
-Disabling USB selective suspend settings, with nothing to avail.
-Disabling USB 3.0 support in Bios
-Reinstalling My pc a million times, which i think has screwed my pc over as now its always missing a ton of drivers which cannot be found by repairing driver or updating as it says files are missing which i have to spend ages putting codes from the hardware id tab into the internet.
-Updating EVERYTHING
My specs are:
Intel® Core™i7 Quad Core Processor i7-4820K (3.7GHz) 10MB Cache
ASUS® P9X79 LE: INTEL® SOCKET LG2011
8GB KINGSTON HYPER-X BEAST DUAL-DDR3 2133MHz X.M.P (1 x 8GB)
4GB NVIDIA GEFORCE GTX 770 - 2 DVI, HDMI, DP - 3D Vision Ready
1TB WD CAVIAR BLACK WD1003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
Power Supply CORSAIR 750W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor Cooling Super Quiet 22dBA Triple Copper Heatpipe Intel CPU Cooler
Sound Card Creative Sound Blaster® Audigy™ FX OEM
Wireless/Wired Networking WIRELESS 802.11N 300Mbps PCI-E CARD
USB Options MIN. 2 x USB 3.0 & 6 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Windows 7 Home Premium 64 Bit
Sometimes after restarting my pc it will say CPU overheating error but the CPU will be running at 70C which is fairly high but about normal i think for that cpu when its under pressure and also it will sometimes but not always say this after restarting my pc when i have just booted it and its cool, so not sure whats up here.The reason I have put all my specs are is that I have always had one problem after another with this PC and haven't had it running perfect for longer than a month and wonder if any of you guys know if something needs upgrading?
I just hope someone can help me get this fixed as my computer is basically my life. Please help!
My specs are:
