Decided to fit my 2 500gb old hard drives so i can start transfering some data onto the new 2tb drive i have so i can format and re-use them after.
I knew it wouldnt work instantly, but i installed them, fitted properly, theyr detected, show up in bios, and are detected when i load up windows, i cannot enter the drives however it cannot read them.
So how can i access them?
The old drives used to be set up in RAID 0, and have windows vista 32bit installed on them. the new hardrive has windows 7 64bit installed on it.
is there an easy way to have them accesible to transfer media and such from one to the other without using an external drive and 2 computers?
thanks in advance
thanks in advance
