Wi-fi and Bluetooth not working!
LeeClarke
Had new PC today.
Neither wi-fi or Bluetooth not working.
In control panel/device manager neither are shown. When you click view hidden devices they appear but when you click on the properties of both it says ‘currently the device is not connected to the computer (code. 45)
Any help?
Cheers.
Can you list your full specs from order page so we know exactly what we are dealing with?
Did you run windows updates till they were all loaded when you set up, if not it might be an idea to connect via ethernet and make sure all drivers are downloaded and installed
LeeClarke
Hi. I’ve connected via Ethernet and updates all windows updates. No updates pending.
my order was:
1 x PC SPECIALIST - Tornado R5 Gaming PC - AMD Ryzen 5, GTX 1660, 1 TB HDD & 256 GB SSD
1 x RAZER - Power Up Bundle
Is there a function key that turns WiFi/Bluetooth on an off?
If they show as hidden devices then Windows has seen them at one time, so perhaps they're switched off somewhere?
another possibility to try is delete from device manager then scan for hardware changes which should reinstall the AX200
LeeClarke
I’ve deleted Bluetooth and wifi from device manager then scanned for nee hardware and they are now disappeared completely.
LeeClarke
morning. Switched PC on again today and wifi and Bluetooth have gone again!!
im trying to find the diagnostics tool I ran yesterday but can’t find it. Starting to think there is a problem with the hardware. Any ideas? Thanks.
LeeClarke
Hi. Had a new Pc yesterday. Having a nightmare!
Can’t connect to wi-fi or Bluetooth.
managed to connect it yesterday after several hours and when switched on today it’s fine again.
have uninstalled Bluetooth and wifi drivers and refreshed but they have gone altogether. Any hell would be great. Thanks.
