win 8 help for optimus 2 pls? how to get wifi button to work?
tommo123
i upgraded my win7 ult install to win8 pro earlier today. most seems to work fine. no "!" in dev man etc (uninstalling intel wifi drivers though - GOD that was a pain) but the only thing i can't seem to get working is the wifi button on the top right of the keyboard?
you have power, video, sound and wifi. the audio and video ones work but the wifi one does nothing.
are these the hotkeys? or do i need to reinstall the chipset drivers?
ta
vanthus
Member Resting in Peace
Try Fn and F12. or Fn plus whatever key the wifi symbol is on,you may need to install "hotkey" from the driver disk provided.
vanthus
Could be a driver issue,try running "windows update" to see if any software updates are available,failing that try manufacturers website for compatible drivers.
