Hi all.
I've just taken delivery of a new PC without an OS. I'm struggling to get win 7 64 bit ultimate installed.
Near the start of setup I'm getting a message like : Required CD/DVD drive driver is missing.
It then asks you to browse to a suitable driver, which I can't get past..
Any ideas please, as there are a million+ different suggestions on google and i'd rather have someone here who is familiar with this hardware comment before I randomly try things.
Points to note.
1. I can install win 7 ultimate 32 bit without an issue. Its just 64 bit I have an issue with.
2. My failing 64 bit install is from a fresh boot, with the CD rom as primary boot. The win 7 ultimate 32 bit environment is still on the c drive.
3. Ive read about disabling SATA as that may be an issue, but havent tried it.
4. The install disk is from an ISO burned using nero on the new PC. I've tried 2 different disks and both fail.
Any ideas please? my spec is below. Thanks for helping....
Case COOLERMASTER CM690 MKII ADVANCED CASE
Overclocked CPU OverClocked Intel® Core™i7 Quad Core Processor i7-950 (3.06GHz @ max 3.8GHz)
Motherboard ASUS® P6X58D-E: DDR3, USB 3.0, SATA 6.0GB/s, 3-Way SLI
Memory (RAM) 12GB KINGSTON HYPER-X TRI-DDR3 1600MHz, X.M.P (6 x 2GB KIT)
Graphics Card 1GB NVIDIA GEFORCE GTS450 - 2 DVI,HDMI,VGA - DirectX® 11, 3D Vision Ready
2nd Graphics Card NONE
3rd Graphics Card NONE
Memory - 1st Hard Disk 1TB WD CAVIAR BLACK WD1002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
2nd Hard Disk 2TB WD CAVIAR GREEN WD20EARS, SATA 3 Gb/s, 64MB CACHE
RAID NONE
Points to note.
RAID NONE
