Obviously homeplugs would be a better solution, but I have been gaming on wireless for 3 years on my current pc and never been disconnected. I get a max strength signal where my pc is (directly above the router upstairs)
I'm gonna be ordering my rig on Wednesday, and can just about afford my budget of £1100.
If I don't buy homeplugs this month and use my old wireless pci card instead I won't have to spend quite so long calculating before I order just to make sure I can afford it (trust me, an extra £40 can make all the difference at the end of the month)
Does anybody think this is a wise idea? Half of me thinks 'yep, wireless will do you fine' the other half is like 'just buy the homeplugs fool (in a Mr T voice)
I know you lose a bit of speed through wireless but I only get a 3mbps connection anyway, and didn't actually notice any difference on speed tests when i was wired and had a cable running around the house.
Only 3 days to wait, and then probably the longest 10-12 working days ever
