Z77 Sabretooth Max Temp
salg04086
Hello,
Currently I have noticed that with the warm weather, my motherboard temp is currently at 40 Centigrade. What is the normal for this motherboard and at what is the max temp range for the Z77 Sabretooth Motherbaord??
Would appreciate any advice
Thanks
Salg04086
tom_gr7
Life Serving
that does seem pretty warm for a motherboard, in my opinion - dont work for pcs.
What spec have you got mate? inc case, cooling setup.
salg04086
Case COOLERMASTER CM STORM ENFORCER - GAMING ENTHUSIAST CASE
Processor (CPU) Intel® Core™i7 Quad Core Processor i7-3770K (3.5GHz) 8MB Cache
Motherboard ASUS® SABERTOOTH Z77: USB 3.0, SATA 6.0GB/s, THERMAL ARMOR
Memory (RAM) 8GB KINGSTON HYPERX BEAST DUAL-DDR3 2400MHz X.M.P (2 x 4GB KIT)
Graphics Card 3GB AMD RADEON™ HD7950 - DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
2nd Graphics Card NONE
3rd Graphics Card NONE
Memory - 1st Hard Disk 240GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
2nd Hard Disk 3TB 3.5" SATA-III 6GB/s HDD 7200RPM 64MB CACHE
RAID NONE
SSD CACHE DRIVE NONE
1st DVD/BLU-RAY Drive 12x BLU-RAY WRITER DRIVE, 16x DVD ±R/±RW
2nd DVD/BLU-RAY Drive NONE
Memory Card Reader INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£69)
Change to: CORSAIR 750W PRO SERIES™ HX750-80 PLUS® GOLD MODULAR
Processor Cooling Corsair H80i Hydro Series High Performance CPU Cooler (£69)
Extra Case Fans 2 x 12CM Black Case Fan (configured to extract from rear/roof) (£9)
Fan Controller NONE
Network Facilities DUAL-BAND WIRELESS 802.11N 450Mbps PCI-E CARD (£35)
Modem NONE, I WILL BE USING BROADBAND
Floppy Disk Drive NONE
Firewire NONE
TV Card HAUPPAUGE QUAD TUNER HYBRID TV CARD (WinTV-NOVA-HVR-4400)
Operating System Genuine Windows 8 Professional 64 Bit - inc DVD & Licence
PS The temp I am referring to are in Asus AI Suite 2 under Thermal Radar are
CPU Temp 35 Centigrade
Motherboard temp is 39 Centigrade
Thanks
Salg04086
vanthus
Member Resting in Peace
I wouldn't think those temps are anything to worry about,mines are much the same on idle.
salg04086
Hello tom_gr7
RAID NONE
Fan Controller NONE
Using AI Suite 2 CPU Temp 32 Centigrade
Motherboard 39 Centigrade
Thanks
Salg04086
salg04086
Thanks Vanthus
Do I need to do anything or increase fan speeds in Bios if temp get any warmer??? or is this automatic??
Regards
salg04086
tom_gr7
Life Serving
well, my mobo is nowhere near as advanced cooling as the sabertooth, but mine has a temp of temp of 22.0c in a room which is 21.3c
therefore i would suggest those temps are a tad high for such a high end mobo.
salg04086
Thanks I will contact PCS Early Next week just to confirm that temp are okay
Regards
Salg04086
salg04086
Thanks Guys, contacted PCS . I spoke to Matthew, whom was very reassuring and helpful, put my mind at ease. I was told that the temp are fine, and also that as a general rule the motherboard Temp should not be above 15 per cent above the CPU temp.
Taking into account that my system is overclocked to 4.5 ghz and that the Asus Sabretooth comes with a five year warranty with the high end components I should be okay.
Salg04086
vanthus
Glad your minds been put at ease,as I said,I didn't think there was a problem with those temps but you did the right thing contacting PCS to make sure.
