Benchmark Results Leaderboard | Page 20 | PCSPECIALIST
Here's my results following an upgrade to GTX 970:
http://www.3dmark.com/3dm/11502706
3DMark Score === 10059
Graphics Score === 11504
Physics Score === 13559
Combined Score === 4320
Graphics Test 1 === 55.63 fps
Graphics Test 2 === 45.43 fps
Physics Test === 43.05 fps
Combined Test === 20.1 fps
My FPS's seem to be lower than everyone else's, not sure why this would be. I've not done any overclocking etc, just ran the test after installing the card.
Recluse
Which graphics driver are you on? Try rolling back to 362.00.
PCS won't have OCed it. Interesting, it only reports the base clock on my 970 (my SSC usually boosts up to 1392 without me touching anything). Maybe it's different with Pascal and GPUboost 3.0. Timespy seems to show the GPU OC though. We should have a timespy thread.
MJSWARLORD
Gibbs you tag this "just for fun" ?..... firestrike is free but you forgot to mention steam says you need the base software which is £22 only then will you be able to use firestrike. If you want to see the spec of my rig from pc specialist type "my game breaker rig" into the search box or your browser , my card is a gtx 1080.
You can run Firestrike for free.
You can't customise the run's settings without paying for it, but if you're doing benches to compare to other people's systems then you need to run it at the default settings anyway. The "Basic" edition.
You can also get the non-steam versions here: https://www.futuremark.com/support/downloads
At the risk of being a killjoy:
The leaderboards on pg 1 are 3 years old.
That said, it just goes to show how powerful modern laptop GPUs are, with a mid-range GTX 1050 ti beating out all but the most extreme of laptops from just a few years ago. :)
The 1050 ti is about as powerful as the GTX 970M was.
makmcn
I'm posting this result from my current laptop benchmark and will add the results from my Octane IV 17" when it arrives tomorrow
https://www.3dmark.com/fs/14409463
makmcn
Looking at my post above...... BAHAHAHAHA! Potato laptop!!!!
Octane IV 17" Laptop came yesterday came yesterday - here's the benches......
