Ok got a new PC from here about 3 months ago, will post spec below and until last thursday was really happy. Came home thursday night switched on PC and it booted ok loaded windows ok but then came up with weird screen res (800x600). Went to change res back and then came across problem. Instead of graphics card showing as GTX460 is showing as Standard VGA adapter.
Ok so first thought was problem with graphics drivers. To cut story sort tried everything i could think of, tried unstalling drivers and loading new drivers (got error message card not suported). even opened up case to make sure card not lose or powerlead was lose. All looked ok.
Rung up PCspecialists Friday morning and had long chat, they talked me though trying to reinstall drivers ve device manager but no joy.
Should say was going away for long weekend so was short on time, anyway was left that only thing they could surgest was to try reformating machine and if that did not work to send it back.
So got home on Monday ready to have to face upto backing everything up etc and then reformatting machine. Guess what switched on machine and everything worked. GTX 460 showed up on system and all worked. Rung up PCspecialists to update them and hoped that was that. I also had yesterday off so was playing on machine all day without problem.
Now come home from work and guess what machine not seeing graphics card again. Course got home after helpline closed so can't ring um till tomorrow after work.
Now i don't know what to do, to be honest was always unhappy about idea of having to reformat machine and am thinking it's got to be fault with card. If problems were with graphic drivers would think it would just not work. Not keep working & then not working. Anyone got any ideas. I'm stumped.
Thanks Nick.
Spec below:-
Case COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE
Processor (CPU) Intel® Core™i5-2500 Quad Core (3.30GHz, 6MB Cache) HD graphics
Motherboard ASUS® P8P67 PRO (NEW REV 3.0): USB 3.0/SATA 6Gb/s, cossFireX™ & SLI
Memory (RAM) 4GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (2 X 2GB)
Graphics Card 1GB NVIDIA GEFORCE GTX 460 - 2 DVI,HDMI,VGA - DX® 11, 3D Vision Ready
Memory - 1st Hard Disk
2nd Hard Disk
1st DVD/BLU-RAY Drive
12x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW
600W Quiet 80 PLUS Quad Rail PSU + 120mm Case Fan
Change to: 800W Quiet 80 PLUS Quad Rail PSU + 120mm Case Fan
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE CPU COOLER
Network Facilities
Genuine Windows 7 Professional 64 Bit - inc DVD & Licence
Thanks Nick.
Spec below:-
2nd Hard Disk
Network Facilities
